Rear End Question *Help Soon Please*
1996mustangGT
Guys I've come across a good deal on a complete rear with 4.10's. However its out of a Fox. Now if I switch to my 5 lug axels will the rear still mount up the same and work?
Thanks in advance,
Tim
Paul
Wouldn't it be a LOT easier to just swap the 4.10s into your car rather than swapping the entire rear, and all the brakes?
1996mustangGT
It takes me like 2 or 2.5 hours to swap the entire rear by myself.
To have the 4.10's installed is a little over my head, and it cost around $150-$200 :(
So if possible I'm just swapping the rear out
1996mustangGT
Okay since were not answering the rear question lol
If my carrrier for the ring is busted (thing with the spider gears in it) if i replace the carrier with another one, do i have to re-adjust the pinion depth and the shimming etc, etc
1996mustangGT
Sorry to sound like a smartass lol
Not trying to be difficult just found one for nothing so I have to pick it up, swap axels and bolt it in...
:D
i didnt mean to sound like a smart ass :sad:
the lenght is not the same, foxes is a lil shorter but still work,as Paul stated above its gonna take a lot of time maybe modifications to get everything on there.
and yes if you swap gears you have to set everything with in specs. such as back slash not hard if you have the tools and time.
1996mustangGT
No no no I meant I didnt mean to sound like an a-hole not you!
You were helpin me out! :)
So i guesss the mounting points for certain things are different...hmm ill have to check out what all is different.
You are probably right, it may just be easier to have the 4.10's reinstalled in my current rear.
tim=missin the gears :(
2slo95fiveoh
Lawrence, Kansas
Well the mounting points aren't different as far as control arms, driveshaft, that sort of thing. The Sn95 axles are slightly longer than the foxes
because of the brake caliper clearnace.. The sn95 have a caliper bracket that extends out to hold the caliper, thus requiring more axle length.
If you wanted to swap everything over, you would need to swap axles, all the brake stuff (brackets, calipers, rotors etc..) not to mention the brake
lines, ABS mumbo jumbo.... I would just swap the carrier w/ gears if the rearend is a good enough deal, if not, just 31 spline swap, and call it good!
1996mustangGT
Cool cool!
However I am amazed at how difficult everyone makes swapping a rear sound! I did it by myself in the driveway in like 2 hours lol.
Anyways thanks for all the help guys! I really apreciate it :)
Venom351R
Maine
its not that doing the gears is hard its setting them up that gets people. You need a dial indicator and to correctly set the backlash, proper amount of shims, press..exc exc..
1996mustangGT
Yeah If I had any brains I would buy the needed tools and learn how to do it.
I could make MILLIONS! Okay...maybe not....but I could make some extra cash lol.
badass98svt
It's a direct swap.
The rear itself is the exact same length as the SN.
It's the axles that are different, and you'll be swapping those too anyway.
I say go for it!
