rebuild a 5ohhh
Import Slayer
Charleston, SC
OK I grenaded my 5.0 this weekend now I have a complete motor out of an 87 gt. I'm taking it down and machining the whole thing. I ran a e303 cam in the last motor I was thinking of running an x303 in the new motor. Would I have to run anything different? Ive been running the stock e7's as well. Would I have any valve clearance? And I would like to hunt down some gt40 head's if they would clear? Any suggestion?
97FloridaGT
An X303 will probably be very close with P2V clearance. I think your money for a cam would be better spent on a custom grind, but that's personal opinion. Regardless, with a cam that hot your heads will be holding you back in stock form. GT40s would be a decent upgrade and relatively cheap. Check out Thumper of Orange Park, they have a good reputation and decent prices for those on budget builds.
94Snake
Valdosta, GA
i think an X303 is too big for you....your overall performance will suffer.....but i'm guessing that your car is pretty much stock, but i don't know....
What rear gear are you running?
What transmission are you running?
If an automatic, what size stall converter?
I wouldn't spend the money for a custom ground cam unless the prices are comparable to a stocked shelf cam, reason being that if you're pretty much stock....i don't see much of a gain for the money.
I
Import Slayer
Charleston, SC
I have bolt on's and I'm running my t5 with a spec stage 2 in front and 3.73 behind it. Anything comp makes that is compared to the e303?
94Snake
Valdosta, GA
That's good you've got a T5 with the 3.73s, that won't limit you on camshaft selection.
I went to Comps website and their descriptions are really vague, so you'll have to call them, which i'd recommend that you call a camshaft company and talk to them anyway. they'll be able to help you get the best bang for your buck when it comes to selection.
ProKiller
PA
personally i'd just rock that e303 and spend that money on better heads.
