Rebuilding the rear
Venom351R
Maine
That kit will fit both 28 and 31 spline axles. Providing that your axles are stock which I assume they are then you have 28 spline axles. The only thing you cant mix is different spline count on the axles VS what the differential is meant to accept. Such as you cant put 31 spline axles in a stock differential which accepts 28 spline axles. But for the rebuild the kit is good for either one.
