RedTwilightZERO 1996 Cobra Build
RedTwilight
RedTwilight
Roxboro, NC
RedTwilight
RedTwilight
Roxboro, NC
Not much of an update, but maybe it will motivate me to get more and more done!
I purchased some brake line and a "T" fitting for when I do the IRS swap.
The Cobra is currently sitting in the shop waiting for me to start stripping body panels for the body work and other stuff.
RedTwilight
RedTwilight
Roxboro, NC
Got some Carbon in thanks to @ThomasW. It's one of his firewall panels. It looks great!
Also pictured next to it is the carbon cowl panel from Carbon Driven. I got it on clearance before they went out of production.
Now I need to save up to get the rest of the carbon pieces I plan to use..
01yellercobra
I have that set up on my car. Made a noticeable difference in the stiffness of the body.
Tony
ohio
Not much but I did place an order for a Stifflers Fit System while the 10% discount sale is going.
Maybe this will motivate me to get started on the Cobra once again.
Nice update!! So when do we see this sexiness on the car?
RedTwilight
RedTwilight
Roxboro, NC
Not sure when that's gonna happen yet. I've still got the Cobra brake 5 lug upgrade for the 93 to do. Also need to clean the shop up enough to replace the heater core in a Durango.
Then I'll need to see if my dad has one of his drag cars on the lift to weld them in.
RedTwilight
RedTwilight
Roxboro, NC
Nice, have you installed the subframe connectors yet?
No I have not yet. I've got to wait until my dad gets one of his drag cars off the lift. Then after that, hopefully I'll be able to at least get the sub frame connectors on. Then later get the jacking rails and diagonal bracing in.
DKblue98GT
When you do install them would you mind taking pics of how you do the trans mounts?
Thanks!
