Regular Mreaintenance
lutter94
South Dakota
Curious...for those of you that change your own oil, what else do you check over at each oil change? i. e. do you check the diff every time...etc....
joekd
Ct
At every oil change I check all underhood fluids (coolant, brake fluid, easher, etc) I also triple check every spark plug boot is tight and look at the air filter
Every other oil change I put on new wipers (overkill yes but I would rather spend a couple bucks then be on the road in the rain with no vision)
Tranny and diff fluid I change once every other year or so, if you don't have a leak there is no real reason to check them and all that synthetic fluid gets pricey
TxCobrA98
i just do my oil and filter and check coolant level. i check everything else when i feel the urge to.
Win
Kennesaw, Ga
I go over everything about once a week, just because mine is getting up in age and up in miles so i figure its better to be safe then sorry.
mikey94gt
I inspect the underside while im under there, check all fluids, check wheel bearings every other, tires for nails, etc, brakes for wear, among other things. oil leaks are always being looked at.
L
lutter94
South Dakota
ic, well my diff started leaking the other day, its at home now, im driving my pick up now. But i tried to take the fill plug out of the front of the diff and it was a bear, i never did get it, not enough room under the car when its on ramps. So i'm thinking about putting a Mac/ford racing/whoever diff cover on it that has the fill and drain plug on the back where its easily accessible. Plus the diff is leaking out of the gasket so the cover comes off anyways....
joekd
Ct
The drain and fill plugs are great, I put a TA performance one on my last GT and plan to do the same on this one
mikey94gt
I have a TA performance girdle waiting for gears. 3.55's would be nice, but im broke as a joke!! this girdle says Saleen on it, nicely ball milled into the bridge support.
Paul
I wonder if this thread might belong in the "Regular Maintenance" forum???
94 DropTop
I just change the oil and be done with it. Im constanlly tinkering under the hood of my cars
danielson631
if you get a new diff cover remember not to fill the fluid up the the fillhole but to check exactly how much fluid to use
95BlkCobra
pasadena california
i change my oil every 3 months weither it needs it or not. car gets mobil 1 with lucas oil stabilizer and wix filter. while its up there i check and lube everybushing in sight with silicone spray lube. also do a power steering flush(fucking ford p/s pumps!!!) check coolant and brake fluid. clean the air filter and maf. rotate and check tire pressure. once a year or so i run seafoam through it. my boss says i over maintain the car lol
