Removing the rear spoiler/wing
delling3
Sterling Heights, MI
'96 GT. Looking at adding some racing stripes to the hood and rear deck. Strip kit I am considering has a section for the rear deck, but the spoiler needs to be removed to install the stripe. Once the strip is installed, I will reinstall the spoiler. Is it as simple as bolt off/bolt on? Looks like bolts go thru from the underside of the deck lid? Any gaskets that need to be replaced, and if so, are the available somewhere? Or will I need to come up with some gasket material and cut my own?
Benni614
Delaware
R u asking is there a gasket under the spoiler? No there is not. Should be 4 nuts under the trunk to remove and then its off
Sent from my SM-N975U using Tapatalk
senior001
