Replace front bumper
mxsuprastang
My brother in law gave me his old (as in time, not looks) white GT front bumper. The paint on mine is cracking like nobodys business so I wanna replace them. Since they are the same it shouldn't be too hard, I understand that. The only thing is, I've heard about riveting and such, basically, how do I go about the swap?
Dalamar
SLC, UT
the side brackets should already be rivited on.
the hard part is removing the tabs that slide under the headlight/front end area. you may have to cut them off your old bumper.
there are bolts on both sides you have to access the nuts from the inside/wheelwell area.
and the front isn't to bad.
good luck with the swap.
mxsuprastang
I did it and it was surprisingly easy. You're right though, the tabs under the headlight mounts are the hardest, but no breaking was necessary, just some TLC from under a lowered car in the AZ sun haha. Worked out perfect and it looks great. Thanks for the reply!
