replacement plenum?
GT3FC
Phoenix, Arizona
so while putting my upper plenum back on after installing my nitrous plate I accidentally put the wrong spacer in for the 5th mounting bolt on the plenum and I kinda brokeded it. I saw that Latmodle Restoration has a trick flow upper plenum for a pretty good price. anyone used one before?
Trickflow plenum:http://www.latemodelrestoration.com...tang-Gt-46L-2V-Black-Trick-Flow-Intake-Plenum
and I guess it wouldn't be a very exciting thread if I didnt show y'all what I broke so here ya go:
MustangChris
Aurora, CO
ive never used TF. I always suggest Acuufab whenever possible, but TF has a lot of history behind them. I'd trust their name.
Also, we get sponsor discount! :)
additionally, why you no use right spacer?!??!!??!
GT3FC
GT3FC
Phoenix, Arizona
Well I had an intake spacer and I jus assumed the spacer from that would be the right size for the nitrous plate (bad idea). The Sr spacer I had looked shout the same size as the nitrous plate so I just went with it (another bad idea as you can tell) haha I'm not too concerned as it isn't a main mounting point but I want to get it replaced as soon as I can
I have the TF plenum.
I like it. No complaints here. Good solid piece.
joekd
Ct
Is that a stock 4.6 plenum? If so I think I have a couple of them in my basement still
joekd
Ct
Ok, well if you decide you just want an OEM one I'll sell you one with TB and all for $20 plus actual shipping (can fit it in a flat rate box)
It's been painted red but still has the pretty pony badge on top and everything
Shifty Powers
Where the wild goose grows
honestly a new plenum is a new plenum. As long as it is aftermarket. They will all work better than stock. All it creates is a larger, smoother area for the air to flow through. So TF or accufab will work well. Pair it up with a nice 70mm TB and you will be all set.
