I am not near the car right now, but the original TPS that was in there was reading 3.7-9v at close but I didn't move the butterfly to see if it went to 1.00 with that one, but I am going to assume it must have since this new one is reading the same closed voltage.
Definitely can't be installed backwards.
Here is what I know-
Car ran fine when he took it to work, came out of work, gave a "quick" I want to start but died and hasn't started since.
- Distributor was in need of replacing as the bushing were shot and it squeaked, was hoping it might be the PIP and then be done with it, but its not it. Another distributor is installed and no go.
- Will run on ether only as long as I spray.
- 38lbs of fuel pressure and I hear the pump turn on, tested at the schrader with a Fuel Pressure Gauge
- Coil wire is producing spark as I stuck a screw driver in the end of the wire and put it near ground.
- Pulled off wire 5, stuck screw driver in and held near ground, spark upon rotation.
- took off an injector connector and it has 12v to the red wire upon key turning forward.
I ran codes and we already know the transmission needs to be flushed and shutter fixed as it shutters, so that is some of the codes but the damn thing goes so fast I am having a hell of a time keeping track of what code it throwing, here is a video.
http://youtu.be/DMEEjWsryFU
With this new distributor, this is more then I got before.
http://youtu.be/6YX6anSpwSk
I also tried a Mallory Promaster Classic Series coil I had laying around, and ran some jumper wires to the leads from the engine harness, has good spark with both this and the stock coil.
I just picked up at Noid tester, no blinky dinky
Never used one, I assume just plug it in to injector harness, crank and watch for a light corrrect?
I used the Bosch-2 in the bottom row as it fit.
Ran codes again
Codes are as follows (which I know I have to get the trans flushed and shutter snake oil put in )
Anything here a clue for no injector pulse ?
- 553 - Air management 2 circuit failure (AM1/TAD)
- 564 - Electro-Drive Fan circuit failure
- 558 - EGR Vacuum Regulator circuit failure
- 565 - Canister purge circuit failure
- 652 - Modulated Converter Clutch Control solenoid output circuit error
- 625 - Electronic Pressure Control driver open in EEC
Which led me to the TPS and where I am right now....no injector pulse and from what I can tell the TPS is not reading right.
I got the voltage off the 2 bottom wires, which I forget what colors they were, but it wasn't the top redish one.
