ReplicaR's Mustang build *finally on track again*
R
ReplicaR
Yeah, I really like how they fit. You can see that they were made for open wheel racing because of the padding around the knuckles. My Sparco gloves were a LOT thinner.
R
ReplicaR
Goodbye Sparco, hello Alpine Stars. Decided to replace my 8 year old gloves and balaclava for some updated stuff. Alpinestars stuff seems like a tighter fit, partially because it's newer, partially because it's designed like that. So far very happy with it.
white95
Apex Junky
Admin
Prairieville, LA
D, do you still have the pictures of how you boxed your radiator? Your pictures won't load (likely an issue with the local IP) and if I recall it was simply metal bent on a brake and screwed to the core support. I'm finally making large strides towards my chassis and suspension mod list catching up to the engine :)
white95
Apex Junky
Admin
Prairieville, LA
ReplicaR's daily driven road race Mustang build *Roll bar is in Page 21*
Thank you sir. Thanks.. I'm going as far as removing the bumper in lieu of a bash bar.
You ever considered adding a vent in the bumper like that ragtop cobra Griggs built?
R
ReplicaR
Yeah, I have thought of it, however the real step up for me will be moving to a Ron Davis radiator. Current one is ok, but I want to be able to pound on it in 100 degree heat for a full session and not have to worry about it.
white95
Apex Junky
Admin
Prairieville, LA
I've been considering a Fluidyne but will look into Ron Davis. I also have an oil cooler/fan combo to mount as well as a butt load of other stuff.
R
ReplicaR
I am selling some of my cooling stuff, send me a PM, if you're interested.
R
ReplicaR
Alright, moving onto next logical step in the track car prep. I've thrown a few things into a spreadsheet, just to start off. Some of the stuff is free, some is cheap, some are extremely expensive with not a lot of gain. Either way, here is the spreadsheet.
Parts To Be Removed
Parts To Be Replaced With
Weight Removed
Overall weight with full tank of gas
Date
Upper Control Arm Mounts on ChassisN/A
Upper Control Arm Mounts on AxleN/A
Quad Shock Mounts on AxleN/A
CarpetsN/A
Sound Deadening MaterialN/A
Standard MirrorsLightweight Smaller Mirrors
MM Heavy Duty Rear Control ArmsMM Road Race Control Arms
Parking Brake AssemblyN/A
Heater BoxN/A
Glove CompartmentN/A
Center ConsoleN/A
Stock Seat beltsN/A
Recliner SeatsFixed Back Seats
Wiring for Radio AntennaN/A
HID BallastsStandard Bulbs
Front Factory Bumper SupportFront Tubular Bumper Support
Rear Factory Bumper SupportRear Tubular Bumper Support
Factory Steel TrunkCarbon Fiber Trunk / Pin On Fiberglass Trunk
Factory Fiberglass HoodCarbon Fiber Hood / Pin On Fiberglass Hood
Single Piece Front RotorTwo Piece Front Rotor
Single Piece Rear RotorTwo Piece Rear Rotor
Remove ResonatorsN/A
Rear Exit ExhaustSingle Side Exit Exhaust
Air Bags / HardwareN/A
Factory Steering WheelSparco Steering Wheel
Remove SideskirtsN/A
Speakers / Head UnitN/A
Factory Steel RoofCarbon Fiber Roof
Sun VisorsVinyl Windsheild Strip
Polished Steel Coolant Overflow TankSmaller Aluminum Coolant Overflow Tank
Factory Side VentsFlat ABS Plastic Cover Without Vent
Windshield WiperN/A
Water Sprayer ReservoirN/A
MSD 6ALN/A
Battery Relocation KitMove battery to original place
R
ReplicaR
[video=youtube;r_z2z4s72nE]https://www.youtube.com/watch?v=r_z2z4s72nE[/video]
Today I decided to test my GoPro. Having roll bar has finally enabled me to mount it where I want it, so I was able to play around with multiple mounting positions and two cases (Skeleton Case and Waterproof Case with Skeleton Door). The video above has produced my favorite outcome. What I found was that mounting it on harness bar and using a lot of links to place the camera where I wanted it, has created a lot of vibration and instability. I ended up mounting it on a main hoop cross bar and using skeleton case.
evilcw311
Most Evil Member!
Louisville, KY
Only problem I see is that ugly mug in the drivers seat!!! :)
Just playin dude!!! On a side note tho......
Is your seat not bolted in or what?!? You were bouncing around like the worst bobble head doll is ever seen!!!!
Track car br0. Its gonna be stiff. My car rides the same. Bounce bounce bounce bounce :dancing-trooper:
evilcw311
Most Evil Member!
Louisville, KY
I've driven several track cars before and the seats didn't bounce as bad as his. That looks really loose bro
R
ReplicaR
It's a recliner, what you see moving around is the seat back. Without being fully in the seat, and strapped in, there will be some movement. Nothing is loose, but it will never be as stiff as a fixed back.
dang I thought I was the only one dreaming of a carbon fiber roof. I got the material and just need to invest in the vacuum rig needed...
jeffs mustang
