Reverse light wiring
zigbigadoru
Before cutting and splicing into one of the wiring harnesses I want to be sure that this black/pink wire on this connector, located in the passenger footwell, is the reverse light wiring?20250820_201419.jpg20250820_201414.jpg
weendoggy
Maybe this will help. Out of a 2002 diagram but same as 2003 as well.
drivers side fender? I will check my 94/95 electrical bible that shows all the pin-outs but with it being from a different year, and just because you always should check the wiring in some way before tapping into it. When I did alarms I had all the gm/ford wire colors memorized for a quick keyless entry install but I still tested each wire before I connected to it.
Z
zigbigadoru
No passenger. I know the wire I am looking for is supposed to be black/pink but not much else. I will try to grab a few pictures when I get home
Z
zigbigadoru
Z
zigbigadoru
What do you mean? Can you show me? Because the year of the car seems to make a difference on where things are located.
the c201 harness had nothing to do with the reverse wire on the 94/95. There was the motor swap between those years so I am not surprised that it would not be the same.
Z
zigbigadoru
I do not believe that is the harness I'm looking for anyway as it states it's on the driver side
I have decided I am going to tear the center console apart to look for other harnesses and under the dash to identify the correct one.
