T
titokang
Guest
Cars been down for awhile, I've replaced maf 3 times wires 2 times, plugs 3 times, coil, timing chain, fuel pump, icm, and some vac lines. Now the car turns on fine when cold but the idle hangs at about 1300, but when fully warm it outta nowhere idles low and runs rich. The cars loses all power and what confuses me is that I can run it and it'll go past5 grand and it'll stay in first gear. But only when it begins to idle does it not shift? I need to replace o2's cause its time and was thinking the stator in the dizzy cause it dies every now and then, but googled about the tranny and can't find anything that'll affect it. And ZERO codes and somtimes it fails to connect to the ecu? Any ideas would be great, thanks
