RPM Jump
01yellercobra
On my son's 99 GT when he turns on the A/C or defroster the RPM will jump up to about 1500rpm. It does it with or without a tune in it. My initial thought is the IAC. But I've never had them cause a jump in RPM. Usually they go the other way in my experience. What do you guys think?
white95
Apex Junky
Prairieville, LA
Where does it idle prior to turning the AC on? The AC kick should bring the RPM's to around 1000.
How many miles? It's possible the clutch/compressor is working harder than normal due to age related wear [clogged orifice, low/high line pressure, etc]
01yellercobra
01yellercobra
Without the tune it idles whatever the stock rpm is. With the tune it idles at 750 since that's where I have it set.
I want to say it has 167k or 168k on it.
OLD H2S
Silver Spring Maryland
Or the TPS is jumping from 1 volt idle read to 9 volt spark read at the PCM.
Loosen the TPS screws just a little bit and wiggle the hosing back and forth 1mm, twist counterclockwise wise gently and tighten down the screws and see what changes..
evilcw311
Most Evil Member!
Louisville, KY
Huh........I don’t wanna say I told ya.............
......but I will!!!!! I told ya, I told ya!!!!! [emoji1787]
I know, I’m childish at times....... [emoji23]
good call on the IAC, but it took you nearly 35 mins to answer it. If you do not start to do better we might need to discuss a punishment.
evilcw311
Most Evil Member!
Louisville, KY
Between your grumpiness, white bustin my balls, and blak’s crazy hairbrained schemes.....
......not sure I could be punished more!!! [emoji38]
evilcw311
Most Evil Member!
Louisville, KY
Well, actually....
Canaryonvskf’s
