Seat belt sensor cleaning
cryptospook
Seat belt indicator dinging at you even though you're buckled up?
This is the switch inside the seat belt buckle. It gets clogged with gunk and can't activate. Clean it out and you're good to go.
18-19mm ratcheting wrench to remove the nut from the driver's seat. Slide the seatbelt alignment tube off the belt. Flat head to gently pry the seatbelt case apart.
wbarter
