97 cobra procharger f1a build
encasedmetal
So I guess I will finally post more details about my car as I am very close to putting the motor back in the car. this past weekend I did final assembly on the heads, and mocked up all the procharger bracketry before getting too far along. Also took the PSR intake fully apart cause JB weld is not what needs to be on this motor- so everything was rewelded strong. I also decided to cut off the EGR mounting location and move my coil packs to that side of the intake above the pass side fuel rail for a clean look, also rewired the wiring harness to accomplish this as well. I really hate that **** eyed #### that vortech and procharger move your coil packs to. so gonna put the motor back in soon and then fab the intercooler piping. I will take pics soon, and ask any questions you want. here's my mod list minus a few parts I will be adding shortly:
1997 SVT Mustang Cobra
Pacific Green
Coupe
Engine Modifications:
2003 cobra iron block .20†over painted black (4.693L and 283.48ci)
Diamond 15cc custom pistons w/valve reliefs and w/top and skirt coating. Offset wrist pins.
Total Seal stainless top ring and Total Seal moly rings
SVT Manley rods w/ARP rod bolts
Forged cobra 8 bolt crank w/custom rekeyed snout
ATI Super Damper 6.79†6 rib harmonic balancer
8†8 rib outer Procharger crank serpentine pulley
ARP harmonic balancer bolt
ARP main bolts
Clevite main bearings
Clevite rod bearings
Race ported 96-98 cobra B heads w/ 5 angle valve job and machined for larger grade 8 cam tower hardware
Crower 68194-32 valve springs with stainless steel retainers
FRPP lifters and rollers, FRPP stainless intake valves, FRPP exhaust valves
ARP head studs
Lazer custom grind billet 4v Camshafts-241/[email protected] duration. 109/116 .530lift and custom keyways
ARP camshaft bolts
FRPP timing chain set and tensioners
Trick Flow adjustable crank gears and billet spacer
03/04 cobra crank trigger wheel
Cloyes adjustable intake cam gears
Fully Ported/smoothed/welded short runner 96-98 cobra intake modified for single blade TB, EGR delete and coil pack relocation.
Accufab polished 96-98 big oval throttle body
Frpp gaskets and seals (heads, front cover, valve covers, rear cover, oil pan, intake, imrcs)
Ford H.O. oil pump w/pickup
97 cobra oil windage tray
97 cobra oil pan
FRPP 9.0mm spark plug wires shortened
NGK TR6 plugs .28†gap
FRPP black valve covers
Moroso breather catch can -8an inlet, ball outlet
Fragola -8an fittings and hose from passenger and driver side valve covers to catch can
Fragola -10an hose and fittings for IAC valve to inlet tube
SCT BA5000 slot style MAF
VMP MAF wiring extension/adaptor
VMP tuning slot MAF 83mm tube: tapped for meth inj., IAC recirculation, and IAT sensor.
Battery relocated to trunk with summit battery box
Moroso battery kill switch
Exhaust Modifications:
Kooks 1 ¾†x 3†stainless headers
Kooks 3â€x 2.5†stainless O/R mid pipe
Borla stainless steel cat-back with welded pro-flo mufflers
EGR and SAI delete
Relocated exhaust hangers
Cooling Modifications:
Stewarts H.O. water pump
160* thermostat
Ron Davis aluminum racing radiator-relocated
AIS stage 1 methanol injection using HEET 99% meth
Redline coolant additive
Complete A/C system delete
07+ Shelby mustang coolant expansion tank, no coolant sensor
Stock 4.6 97 cobra radiator fan
Power Adder:
Procharger F1a polished supercharger 5.40 step up gear, reclocked oil slinger gear and volute
4.00†8 rib double keyed Procharger pulley
Custom 3.75 I.D. filter for Procharger inlet
Procharger big red race open bypass valve with aluminum flange
House of Boost/Procharger Renegade dedicated drive bracket system w/8 rib serpentine setup and tensioner machined for maximum alignment
Procharger 3 core intercooler
3†aluminum intercooler piping- welded
Gates K060605HD 6 rib
Gates K080505HD 8 rib
Drivetrain Modifications:
theT45source.com fully built billet/carbon fiber 26-spline input T45 transmission
SPEC steel flywheel
SPEC Stage 3+ clutch w/ SPEC stage 3+ pressure plate
SPEC throw-out and pilot bearing
ARP flywheel bolts
Steeda Tri-ax shifter
FRPP 31-spline rear differential with carbon fiber clutches
Moser 31-spline rear axles
FRPP 3.73 rear gear ratio
FRPP 3.73 speedometer sender gear for T45 transmission
New 8.8†bearings and seals
Chrome 8.8†rear differential cover
Moroso front wheel studs
ARP 3.5†wheel studs
FRPP FR500 stainless lug nuts
Fuel Modifications:
Glenn’s Performance 94-97 sumped fuel tank -10an outlet -6an return
Aeromotive adjustable bypass fuel regulator
Aeromotive 96-98 cobra fuel rails with modified brackets
Glenn’s Performance -10an 100 micron fuel filter
Weldon 1100-A fuel pump
Racetronix 79lb/hr EV1 high impedance fuel injectors
Painless wiring/relays
Fragola push lock fittings
Fragola -an fittings
Fragola 8000 -6an return line
Fragola 8000 -8an pump to rails line
Fragola 8000 -10an feed line
Suspension Modifications:
Eibach front and rear sway bars and bushings
H&R race springs-no isolators or dampners
Bilstein HD struts and shocks
Stang suspension C/C plates
Steeda X2 ball joints
Stang suspension adjustable rear LCAs
H&R bump stop
Poly-urethane offset steering rack bushings
Maximum Motorsports welded full length SFC
AJE tubular transmission cross-member
Roush/Alcon four piston front calipers non-floating
Baer 14†two piece drilled/slotted directional front rotors
Baer 13†slotted directional rear rotors
Gt rear mustang over-axle brake caliper bracket
Stang Suspension bump-steer kit
Energy suspension poly-urethane motor mounts
½†rear wheel spacers
Eastwood rolled rear fenders
Interior Modifications:
UPR billet interior accessories
Billet 5 speed shifter knob
Billet door seal SVT plates
Bullet pedal covers
No carpet-no sound deadening
No rear interior panels
No seat belts
Autometer electric fuel pressure cobalt series
Autometer electric boost gauge cobalt series
Autometer A/F wideband gauge cobalt series
AIS methanol injection indication LED dash light
Blue LED dash and HVAC gauge lights
3 pod pillar gauge holder
Corbeau FX1 wide seats w/corbeau seat tracks
Raceline 5-point driver and passenger safety harnesses
Maximum Motorsports 6 pt. bolt-in cage with removable harness bar and swinging door bars
Exterior Modifications:
Saleen S-281 wing
FR500 stealth black 18x9 front wheels
BFG KDW1 front tires
FR500 stealth black 18x10 rear wheels
BFG KDW2 rear tires
Smoked front headlights
No radio antenna
Tuning:
SCT Pro Racer Package Tuning Software Advantage III
SCT XCAL 3 handheld tuner
SCT Live Link datalogging software
Autometer Cobalt series digital A/F wideband gauge
Firefold fire wire interface from wideband to XCAL 3
Gateway Laptop
I don't post on here often- but thought you might enjoy this. the motor is back in the car and I am starting the intercooler piping this week, after I move the radiator forward 2"
E
encasedmetal
thanks bud-it's coming along- but don't think all the bugs will be worked out by mustang week
Knuckles@Empire
-Never Forget-
In front of you
are you worried about belt slip at all with the 8 rib? im not sure if you posted it earlier but what kind of boost are you pullied for?
E
encasedmetal
that would be awesome- I seem to remember a bitchin straight run beside a rest area going to flagstaff
E
encasedmetal
here's more pics from today-spool gun is not working so great for welding the aluminum inercooler piping- it's all fabbed up, but gonna clean it up and have it redone with a tig.
where I'm going to mount to bypass valve
how it meets the throttle body
got rid of the stock coolant tank and made room by using a gt500 tank where the battery goes-sick!
stock rear is out for building
battery is now in the trunk
fabbing the exhaust-around the fuel system and stuff
E
encasedmetal
corbeau FX1 pro wides
maximum motorsports- but it will be changed soon and the door bars are waiting to go in as well
Knuckles@Empire
-Never Forget-
In front of you
indeed a bump is needed anything newish bud? and i missed the comment about the straight away out at flagstaff lol. Gimme the heads up ill get my car trailered and well drag all night friend. I dunno if i posted this in my own thread cause im the fukin worst but, i have to get 25.5 spec legal ugh what a pain. But atleast then im cert to 7.5 e.t. Anyways bump for a big ass blower.
gerardosalasgtz
