she is running (1-14-07)
Re: now i am pissed!!!
or if you just don't feel confident you can shell out the 500+ $$$$ for the ModCamponents adjustable gears.
R
Rantheman
95ft-lbs is what it tourque to i think my new idea is to redegree with the timing cover on then re loctite it and tourque it a little more like 100 ft-lbs or something then use the drivetrain to make the motor not rotate then i should have it running tomarrow
i hope this works out for you, i know i would have pulled out the sledge hammer already and done damage...thats why i pay to have certain things done for me...my temper is >:D
R
Rantheman
yeah your probably right after this next time i will just have someone do it for me
R
Rantheman
Re: not as much pissed of now!!!
well i the harmonic balance is toruqued i used the vehicles drivetrain to take on the rotating of the motor so now i just need to through my degree stuff back on and double check everything then tourque the bolts down a little more then i will be on my way. so she won't run tonight but she hopefully will tomarrow
Fets
Woot! Hope everything goes smoothly!
R
Rantheman
Re: I am cooled down to the temp here now !!
i have now modified my degree wheel to work with my fluid dampner and will be setting up some stuff other wise she will be redegreed tonight and possibly a few more parts on
scarface
good, now go eat pizza!
R
Rantheman
ok i am back on the road again both side read 109 center line now and I will start putting on some front accesories and valve covers next
Fets
im coming over with some beers!
94darkhorse
Idawahio
Good luck man. I don't quite have the time on my hands as of yet to dig into a project like that yet. Some day I will dig into an engine.
R
Rantheman
Alright here she is currently somehow i am issing a few bolts so gotta go get some tomarrow but she is almost there should be running sunday
TxCobrA98
Re: Updated pics (1-14-07)
hopefully they didn't fall inside the engine. :noes: :noes: :noes:
R
Rantheman
naw i check numerous times and were very carefull i am sure none fell in
R
Rantheman
go for it matt I know it bugs you being over her but i don;t mind
R
Rantheman
boy you guys are more antsie then i am
Markstang73
