Shock torque
NEW EDG
NoVa
Trying to torque down my new shocks and the shaft just wants to spin free. Put some vice grips on the top to hold it(see pic) but now I have no clue how tight to go. I believe specs call for 30 ft/lbs. Any tips are reatly appreciated.
NEW EDG
NEW EDG
NoVa
This is how far I got. I can't really pull any tighter with a ratchet wrench. So not sure if that's right enough or I need to go further?1000005068.jpg
shovel
The 1994 Specifications book from Ford (the only authoritative reference I have which seems applicable) lists 19-27 ft-lbs for the rear upper shock attachment nuts.
In practice if you've squished down the rubber bushings like 1/8" or so, such that they would not likely produce an air gap when suspension is rapidly cycled then that's appropriate.
NEW EDG
NEW EDG
NoVa
I have to imagine if I can't move it anymore it's at least 20 ft lbs, right?
shovel
I could only speculate. I use a torque wrench on fasteners that are (to my judgment) critical, in particular anything that may not necessarily give obvious warning before catastrophe if assembled carelessly. I've never put a torque wrench on those upper shock nuts/bolts.
