Short throw shifter question
97/4.6w/fangs
My T45 has an issue going into reverse and I hear it's pretty normal. Did a short throw shifter make a difference for any of you with a reverse issue?
Black97GT
had the same issue before I replaced my transmission
put a STS on...and it was probably a little worse
Ciotti
The problem is that reverse is not synchronised on T-45's, the shifter has nothing to do with it. If you pull into reverse and it doesn't go right in, push forward into 5th which will line the input shaft up right and then pull back into reverse and it'll slide right in.
97/4.6w/fangs
thanks for the quick responses guys. Now here's another question, is the synchro problem an easy fix for a transmission shop to take care of?
AaRoN
King Post Whore
mrspeedy69
There is no syncro for reverse so you can't fix it. You may try changing your fluid out to some synthetic like Royal purple, that will help it slide in a little better i would think.
badass98svt
It's normal.
One thing that helps though is too shift into a forward gear first, then put in in Reverse, Goes in like butta
Shocker98GT
If anything short throw made it "worse", not as in making it harder to go into reverse, just the fact that a short throw naturally requires more physical effort due to leverage. Like said above, T-45s don't go into reverse easily unless you put it in a forward gear first
97WhitePony
Im a 4th to reverse man myself... im in the habit of doing it to everything i drive now haha
ScottyDsntKnow
Actually sometimes reverse decides to be a complete cocksucker and just won't go. I just put it into every gear and try reverse again. If it still doesn't work just put it in first, roll forward ever so slightly and try again. It should go right in after that. Hell, I never try to go straight into reverse even when I'm not thinking about it.
Slow95Cobra
3rd to reverse man here, works everytime. or you can hold it in reverse, and SLOWY ease the clutch up to get the tranny to move a tick, it will fall in
TXbluebitch
5th to reverse man myself also, all my friends with my year model always have that problem but otherwise my tranny is a pos
