should I change the plug or gap if I keep fouling plugs?
As the title says I seem to keep finding my plugs black as hell even though AFR was showing ok. With a supercharged 5.0 running trickflow 170 cc heads what plugs and gap would you recommend?
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
What afr are you running and what gauge are you using? Did you make sure the gauge is calibrated correctly and do you have another wideband you could install to compare against?
Also, a lot of idle time will foul your plugs if you aren’t driving it around. A lot of start up cycles can foul them too as there is extra fuel added on start up and it will run rich until the oxygen sensor heats up and come on line completely.
evilcw311
Most Evil Member!
Louisville, KY
Yeah what warrior said............so start driving already!!!!!!!! [emoji6]
Werecow
Virginia
Coil? It's a thought....mines pig fat right now and I had to tighten up the gap but it's got a weak as hell coil on it....
I have two AFR gauges, one with the Holley hp and the plx devices afr on the other side. They do tend to read a little bit off from one another(.5-1ish) but when I mentioned it to my remote tuner he was not concerned. So far 99% of it running has been in the garage. What plug and gap would you recommend just out of curiousity?
lwarrior1016
South Mississippi
Honestly, I really don’t know what plug to run in that setup. I’m not too familiar with running boosted pushrod setups.
I know gauges aren’t going to read the same, that’s just how it is. .5-1 point I guess isn’t the end of the world. What is your target afr at idle?
96blak54
In the shop
Low rpm driving and idle can be heavy on the lean side with no negative affects. Especially aluminum heads.
You gotta find that afr area where the plugs are self cleaning. This is the worst part. Finding that sweet spot your engine likes.
Your plug could still be on the cold side.
What sparkplug is used? Maybe step up a few heat ranges?
Target afr up till 900 rmps is 13.9
I believe they are autolight 23s with .35 gap but don't quote me or curse me for using them.
96blak54
In the shop
I dont remember what head you are running and im sure you are using recommended type plug or of the similar. Meaning the plug protruding to far into the chamber or not protruding enough, down inside the plug hole. Down in the hole with definitely cause black plugs. Do you remember sparkplug protrusion on the chamber side? Hopefully its correct and flush
Dont be affraid of 16.1 afr around idle. Hell, newer cars are under loads driving with 16.1 now a days thanks to multi spray pattern direct injection.
Now once you finally make it tuning in the upper rpms, 16.1 is gonna heat things up a bit.
The cooling system and fuel air mix keeps temps at bay at the bottom rpm and the valves have no problem staying cool especially with aluminum heads.
I would not make the assumption that I got good info necessarily as I do not know what I should to have done all this. Someone somewhere recommended those plugs but I can't tell you who. Not sure how to check protrusion...
96blak54
In the shop
Well....the manufacturer should have plug suggestions. Or at least style type
well its so important you had to quote yourself? :)
trickflow recommends
AC FR3LS
Autolite 3924
Champion RC9YC
NGK FR5
it seems like the searches I do lead mostly to the autolite or ngk being used.
01yellercobra
I've run NGK's in multiple boosted set ups with good results. After having a set of Autolites fall apart on me and a friend I switched to the NGK's.
Thats really rich for idle. As said lean it out to stoic at least. Granted mine is a mod motor, but it idles around 14.7 and cruises a tad leaner than that.
I think I will try the ngk's this time after hearing them mentioned a few times. I am am going to hold off on making any tuning adjustments until I do get it on the road a little more, or at all really... I have been fighting with getting the front end aligned enough to get it to the shop to get it fully aligned but after more then a few tries I might just have it towed in.
joe65
you might have seen this. The autolites aren't typically known to be bad?? I've used ngk on my audis and really liked them.
http://www.efidynotuning.com/pre.htm
Pushrod SBF TFS Twisted Wedge 302 5.0 Autolite APP 3923 - 0.032"
that's his rec. for a boosted pushrod with twisted wedge heads.
I am not saying they are bad I am sure its something I have done/am doing to it. I just was not sure if there was not something better I am sure like we all do. I had been gapping them at .035 so I will try .032 this time and see if it helps. If not I can go back to .035. Its nice to see some data for the first time really as it seems that most of this is locked up in peoples heads.
01yellercobra
Just remember generally a tighter gap can lead to idle and part throttle issues. I don't see you having an issue at .032" or .035". But just don't go crazy.
I still say lean out the idle about a point and see how it acts.
95opal
/\ this but i would lean out the idle first.
96blak54
In the shop
AC FR3LS
Autolite 3924
Champion RC9YC
NGK FR5
Not sure how i quoted my post...weird!
Anyhow, yes the ford related sparkplugs have gone to crap. NGK are my pick as well. When you build crazy crap like 18:1 compression engines, you find the differences in sparkplug quality and NGK rank high in consistency.
senior001
