If you mean in the car then yes, there are two actually independent of each other. If you mean some kind of off board gauge of some type then no.Try some brake cleaner or carb cleaner? You could try some starting fluid too just be careful around hot parts, that may help find your leak. May be a dum question but do you have a vacuum gauge?
Is it reading a lower vacuum than it used to run before whatever happened to it? That would definitely isolate if it's a vacuum leak or something electrical or mechanical, unless I missed something and I'm completely off the ball here...
Side thought, could it possibly be related to when you changed out the harness to the battery charging system? Possibly bumped another harness and unplugged something or even partially unplugged? I was going back thru your posts and saw that you changed it out and I know anything's possible...
does the seafoam mess with the oil that it needs to be changed or put some in the oil? It certainly doesn't have 3k miles since the last change, not much run time at allChange the oil after you seafoam it
And gas in your oil will kill your bearings......ask me how I know that...
How do you know that?????????
I don’t know how much it took, but I know it was only from about 20 minutes (collectively) idling super rich. Then it got tuned and I drove it 2k miles and it gave up. Fuel doesn’t lubricate like oil does.Ouch. How much fuel does it take to do that?
Sent from my moto z3 using Tapatalk
