Smog bracket from LMR
sn951992
sn951992
Anyone know what size bits go in the smog pump bracket an what about what size the bolts are for the cross over tube
shovel
If you're deleting the secondary air pump why would you run a dummy pulley instead of just running a shorter belt? dummy pulley is just extra weight the engine has to spin up and spin down..
I don't know what size bolts those little covers are, most people just use threaded thermactor delete plugs to close off those holes when deleting the crossover pipe.
