smog pump delte, idler pulley necessary?
mmakam2
I used a 89.5" belt to delete the smog pump, everything else is stock, but it isn't long enough to go under the idler pulley, is this necessary or can I run it without that pulley?
I think the idler is needed to help in alignment of the belt. The belt at the top of the motor has to travel a long way, the idler has edges to keep it aligned between the other accessories.
I think I used a 91.5" to bypass my smog pump when it started making noise. (all other accessories installed)
mmakam2
do you think itll be fine for now? do you think itll spontaneously break, or just start to make noise
If you drive like granny you should be ok.
I don't think the belt will break as much as I think it'll just jump off. Then who know what it will wrap around.
BOS-94-003
I bypassed the idler pulley when i short belted my car. Put alot of ,non granny, miles on it without any problems. You'll be fine.
