Re: SN95 ARSENAL *56K WARNING*
Here you go Dal. :coolsmiley:
Build Sheet - 347cid EFI
Shortblock assembled by Bob Johnson Racing in Fair Oaks CA
Rotating Assembly
Eagle 347 kit; forged steel crank, forged I-beam SIR rods, custom CP pistons and rings, 28oz imbalance.
Heads
Edelbrock Victor Jr heads with cartridge roll clean up.
Intake Manifold
Edelbrock Victor 5.0 EFI
Valvetrain
HiTech Motorsports hydraulic roller cam w/ matching springs, titanium retainers. Top Secret duration and lift. Comp Cams Pro-Magnum1.72 rockers and pushrods.
Fuel Delivery
42lb/hr injectors, stock '94 fuel rails, 255lph in-tank fuel pump, Kirban fuel pressure regulator.
Air Delivery
Pro-M 80mm MAF, Accufab 80mm Throttle body, custom 4inch power pipe w/ cone filter.
Exhaust
Bassani Long tube headers, 1 ¾" to 1 7/8" stepped primaries
Bassani 3" X pipe and 3" Race Series mufflers
Ignition
Performance Distributors LiveWire ignition wires. Crane PS91 coil.
Transmission
G-Force T-5, built by Modern Driveline, with helical gears, synchro kit w/ input and mainshaft upgrades plus steel case girdle. .
0. 59 Overdrive gear
Steeda Tri-Ax shifter
Rear End
8.8" with 31 spline Trac-Loc and extra clutches.
Strange 31 spline axles.
Suspension
Wolfe Racecraft- Lower, single adjustable control arms w/ spherical links; Adjustable, chassis mount sway bar.
Steeda double adjustable upper control arms w/ polyurethane bushings
Stock shocks and rear springs
Welded torque boxes.
Griggs Tubular K-member and A-arms
