qwikstang4me
North Race Cars has brackets and calipers for rear disc brakes. They have the best brackets for cobra brake swaps onto fox body cars, my dad's 91 is running a pair.
Are you saying you have swapped to cobra brakes and kept the GT bracket?
Crap, you are right. I totally forgot they are vented. So it seems logical they would be thicker as well. I wonder about the bracket though. I wonder if they are different part numbers. I can see it being easy to "accidentally" put GT brackets on a Cobra caliper and if that would cause rubbing...
I had issues with my rear brakes - they would make a groaning/rubbing noise on hard turns. Even though I bought a Cobra kit, I now wonder if I did in fact end up with GT caliper brackets?
See original pic, if it has the cross bar = cobra, no cross bar = v6/gt.
You need cobra pads with the cobra rotor. They are thinner, to account for the thicker rotor. If that could be the case.
Yah, I had Hawk HP+ Cobra pads, front and back. I think the issue was the area from a previous pic that was supposed to be hogged out was actually contacting the rotor when the car was getting laterally loaded from turns. I also suspect there was something wrong the calipers themselves. I have new calipers now for the rear, going to see if that changes anything. FWIW, part number on them is M-2320-CR.
did you install these?
