I have the stage 2 boost controller kit. i'm running a procharger d1sc 8 rib conversion and a 2.90 rr pulley. (built motor and such)
my problem is this. while not in boost and while the car is running it is creating a vacuum and sucking the meth/water mix into the intake and down into the MAF. this has ruined my 90mm lightning MAF. when i say sucking i mean when ken (tuner) pulled off my MAF it had huge droplets of the mix all over the MAF and all. As you can imagine this is a huge issues since it jacked my MAF up.
i'm upgrading to a 3'' blow-thru tube but i prefer not to ruin this one.. anyone have this issue or heard of this issue and have any thoughts on a solution. (this caused many headaches while ken was tuning the car)
i've thought about getting a plenum spacer or something and using it instead of the intake pipe but if it's creating a vacuum in the intank i'm afraid that it'll just do the same thing and pull drops of water/meth mix into the engine.
