Venom351R said:
What were you running for tires?
Launching with a stick can be tricky. You will be limited by what your suspension and tire choice is. The more race oriented the suspension and tires are the better the 60' can be. Dont dump the clutch though, let it slip some until you know the tires are going to grab then let it out the rest of the way. Dumping the clutch and mashing the gas usually only works well when using slicks or very close to it.
Tire were 315/35/17 555r's. i know they arent the best but i know people who have cut 1.8 60' with them. I'm almost positive that i was just dumping and mashing. it sucks i only got 2 runs in so i didnt have a chance to fix it.
knuckles4696 said:
whats your suspensions setup?
eibach prokit, bilstein struts in the front, bullitt tokico's out back. HPM Megabite jr adjustable uppers with non adjustable lowers.
I'm pretty sure that my pinion angle is off. I havent had the time to get under my car and check it though. What is it supposed to be set at?
BLCKSTNG96 said:
not bad man,your car looks to be lowered and depending how stiff it is along with whatever tires your running can be the bad 60ft time.if your running the low profile tires chances are thats playing part bc the sidewall of the tire has no flex as well as a street tire is just that.every tenth off the 60ft is a 2 tenths on the big end.if you can cut some good 60s your car has potential for 13s.your 14.3 run for example,if that was a 1.7 60ft,your looking at 13.3-13.4. 1.7 will be tough on a street tire but you get a slick on there,no problem.what does your car weigh and what are you shifting at,id imagine with your mods you should be getting a higher trap speed then that.
Not positive about the weight, the only weight reduction i have is the fiberglass hood, racing seats, no spare/dressings in the trunk and aluminum heads/intake. I was shifting right around 5200. I'm gotta readjust my rockers, a few sound like they've gotten louder and while i'm in there i'm gonna recheck my pushrod length.
Things just dont seem to add up with my car and idk where to start looking for missing power lol i only put down 266 at the dyno but i think that is partly due to the tuner not being able to pick up a torque reading.
