Someone educate me!!
tvsn95
OK, I have postulated before and SOOO here I go.
60lb Siemens work great,( (American Made) the ONLY reason for the small injectors is that , OLD large ones were hard to get a clean idle. same can be said for the Chinese ching chong, stuff that some of the Big guys sell. Tech has come a long way but when you are spending 200-500$ for injectors get the ones that work FIRST. Remember, if you change injector the tune is also changed...sometimes very drastically. So do it once and done.
I put 60 Siemens in all the turbo and supercharged engines/cars that I build and tune... 302s and 351s.
you will make enough to destroy your car and wallet.
I make 750hp and am running 80% duty on mine. Mine is a daily street car, so drive-ability it keen. Also, I know I have said this before but when you boost you WILL run out of fuel system, the very min is an Areomotive 340lph. and you WILL need to up the lines. The rails will support 500 or so (SN95) NOT FOX rails.
Quantam sells an enlarged ,intank hanger with AN fittings. get one and install -8 supply and -6 return W/ a remote regulator, set to 40lb idle.
I run twin Walbro 255 externals. the car I am building now I am using an 400lph in tank that I have no experience with. I will learn soon if it works OK. LOL
Callmety24
Callmety24
Afternoon guys, ive noticed my steering is getting more and more loose as ive drove it and have to come to the conclusion that the cause is the rag joint, ive been looking at some replacements that eliminate the rag joint for a u joint, was wondering if any of you have done this mod and how much of a difference it makes in the feel of the car
Sent from my SM-N970U using Tapatalk
Plenty of us have solid steering shafts. The common go to is the maximum Motorsports shaft. Very good quality and gives a more connected feel between you and the car. The steering will be more responsive to your input as well.
Callmety24
Callmety24
Perfect, thanks boss [emoji120]
Callmety24
Callmety24
Hey guys im working on wiring in the headunit today and found these connectors not hooked to anything an cant find anything to go to them, any ideas what they are? They are located under the dash on the center console area. Thanks in adavance [emoji120]
the 2nd one is your obd2 port that doesn't work. They installed them because the v6s used it and they knew they would be changing over in the next couple of years.
The first one I think goes to the airbag computer thingy if I am not mistaken but it is a bit of a guess.
Callmety24
Callmety24
May I humbly suggest full length sub-frame connectors. Stiffen and support the chassis for what you plan to do HP-wise.
A pan hard bar is super stiff so I’ve been advised that it’s better for drag cars not drivers/canyon carvers!
Look what fed ex dropped off yesterday [emoji16][emoji120]
Callmety24
Callmety24
and once again I have to ask who don't LOVE M&M?!
Ive gotta say, this is the first product ive bought from them and after seeing the quality, i will definitely be a return customer [emoji120][emoji120]
they are certainly not the cheapest, and there might even be better but I rarely hear a complaint about quality.
tvsn95
The one I use are not M&M's but appear very similar, Weld those in using a jack to hold in place pressing up tight then run your rear mounted battery cables through them . you could also run your fuel hoses inside if you plan aheah.
these really made a diff on my setup.
Callmety24
Callmety24
Hey guys. I found this turbo setup on fb marketplace and was wondering what your thoughts are on it, is everything there that i need, is it worth it, etc thanks in advance[emoji120][emoji120]
Its hard to say since they never mention a single brand short of the anderson pms. The fact they left it off tells me its either a no-name china brand or that he has no idea what he is selling.
Daryl
SoCal
Hmmmm... trepidation’s. just be careful you’re not buying a can of worms.
Callmety24
Callmety24
Brand concerns noted, i will check into that and see of i can get a brand name, aside from that, is everything there?
it looks like a fairly complete kit from the pics but its hard to judge. If I could not get the brand of the turbo and a little more about how long it was used I would not even consider it myself.
EdgarR213
