someone help me with which spacers I need
x182dan
I have 18x10in rear wheels with 285/35/18 tires and a +38 offset. I think my rear tire might be hitting the inside wheel well on some corners. I was thinking spacers would do the trick nicely. What size should I get is one inch the standard size that most people get?
Dan
xander0561
I got mine from Jegs. They have them all the way up to 2 inch I believe... But your going to have to get longer studs if you run spacers. Unless you get the spacers with the studs in them.
fixthedoor
The spacer you get is mostly a matter of what look you want. Measure distance from fender to face of rim/tire and go from there. However, I don't know what distance you do not want to exceed.
X
x182dan
I do plan on getting the ones with the studs in them
