Sound clip of death.. :/ Throwout bearing??
Twista
Link to big semi-useless thread lol: http://www.sn95forums.com/forum/index.php?topic=16628.new#new
and sound clip:
http://media.putfile.com/MIC-2005-07-17-00h38m49s
Clicking is not usually a t/o bearing noise--usually a faulty bearing will start with a metal to metal sound when the clutch is pushed in slightly--just enough to put slight pressure on the bearing. It is almost a whurring sound at the beginning but more of a grinding sound near the costly end.
This sounds exactly like my problem. So i would guess its the throwout bearing. :dunno:
19mustang95
tht is your throwout bearing, I called it...
I remember those noises because i had them a month after i had my car. it sucked driving that thing to the shop to replace the clutch. :hammer:
T
Twista
Thanks bud. You did call it 1st :angel:
Sounds nasty regardless. I can still drive it, but sometimes the clutch padel gets kind of loose than its stiffens back up. Well, im glad its nothing serious. Well, i hope its nothing serious, but the smoking coming from under the car when i pulled over after downshifting was strange. Oh well, ill get someone to look @ her soon.
Now am i still looking @ an $500-600 install. If i buy a clutch kit.. does a new throwout bearing come packaged with it?
Thanks
Schiffy
Norfolk, Va
my HD King Cobra Clutch came with a T/O bearing... I would look into spending the extra $52 on a Steel throwout bearing retainer, as the stock one is aluminum, and once it is grooved, you'll go through T/O Bearings left and right. it's WELL worth fixing now, and not worrying about it later.
G
GREG@SN95
Guest
I think all clutch kits come with a TO bearing... I bought a regular clutch for my car, stock specs... I think it was steel...
T
Twista
Glad everyone is saying its the T/O bearing. i miss driving my stang and its only been 2 days :/ The dumps sounded so good when i fired her up. Oh well.
Paul
+1 Also, make sure you set the appropriate preload on the main bearing when installing the new retainer. Assorted shims can be had as part of various rebuild kits on eBay.
