speaker covers/grilles? 1995
optionizerSS
Pittsburgh, PA
Where to find the rear lower speaker covers? It's a 1995 convertible. Also need a set for a 1999 vert. Plastic tabs broke off. Did a quick Google search and found nothing so far. Has to be someone out there making them?
joemomma
Have you tried eBay? I've had good luck sourcing parts there. Any junkyards/pull-a-part close?
O
optionizerSS
Pittsburgh, PA
i just checked the typical aftermarket sites but assumed if we pulled them from 2 cars and broke them off both of them i'd prefer to get new rather than used...lol
O
optionizerSS
Pittsburgh, PA
ugh. looked most of the day and no luck. only found them used still attached to the 1/4 panel trim and that doesn't help. Would have to take the whole styling bar back out to swap them and even then you have to pop those covers off to get access to fish the brake light wire down through. Gonna have to try to figure out a way to get these ones to stay on unless someone has a better idea
plastic is not hard to glue to for the most part. A plastic welder would be great or just get some plasticweld epoxy from autozone. I actually have some drying at the moment as I have been using it to convert the standard door pull cups with the window/lock holes in it to GTS versions with no holes.
O
optionizerSS
Pittsburgh, PA
used the dremel to grind down the broken studs and bought some 2 part plastic epoxy but want to get some dual lock tomorrow morning to try to get some on the edges to help hold them on. Think I'll be ok with that. If not I could probably pull the material off and drill a small hole and run a couple of screws through into the metal speaker bracket then put the material back on
O
optionizerSS
Pittsburgh, PA
I ended up using JB Weld plastic epoxy. Holding good. Just smoothed down the 'pins' that were broke and coated the tips with the epoxy and all is good now
