Spec clutch feedback
wytstang
Personally I would look for a clutch that slips a bit. What I mean is Spec have a hard bite and put a lot of stress on stock transmissions. I would rather waste a clutch then a tranny. If you don't drag your car you should be fine though.
I have a stage 2, doesn't chatter and it's very streetable once you relearn how to drive smoothly with it. A guy i know locally put the stage 1 in his car and mine felt lighter for whatever reason...
thorco3
IN
I debated for a long time. I really wanted a cf dual friction, I've heard the mccleod (sp?) are good as well.
I went with a spec stg 2, no regrets. works well for me
i ahve spec stage 2.
took quite a while for chatter to quiet.
still chatters in reverse.
functions/performs great.
needed adjustable clutch cable... sadly.
2slo95fiveoh
Lawrence, Kansas
I have heard good things about the spec stg 1 and 2. A buddy of mine had a h/c/i 308 92 GT, and he had a stage one, and he liked it, until
he took it too the track.. Then it would slip like crazy, and sometimes smoke leaving the line. He switched to a stage 2 and has zero complaints.
Another guy i know with a h/c/i s-trimmed 93 coupe has the stage 2 and he said it grabs well, but he might switch to something else. I would stay
away from the stage 3 though. 2 guys i know, both with Terminator swapped New edge GTs had the stage 3s, one split in half on the dyno, the
other lost a clutch fin launching on the street. So, long story short, the stage 1 should be fine for your needs. haha
Dalamar
SLC, UT
I had a spec 3+ and hated it.
Swapped it with a McLoed twin disk.
it is more $ but performs/feels so good, night and day difference.
Sorry Javi, havn't tried the stage1
Slykin
Tyler, Texas
I'm interested in this too. I'm kinda on the lookout for a good clutch. I still have the stock one and I want to burn it with FIRE!!
Win
Kennesaw, Ga
I have heard great thing and horrible things. I have a Centerforce Dual Friction Pressure plate and a Ford disc and well yeah it held up great for over a year with a bolt missing. I am now going with a SVE mongoose Clutch. Basically a King Cobra clutch with a little more power holding capabilities.
Win
Kennesaw, Ga
MustangChris said:
bolt missing, win?
yeah i find out almost a year later that my old roomate when he helped me tighten the bolts i gave him the torque wrench i said when you hear a little click stop. Well yeah i guess he is hard of hearing or something. I found this out back in Dec about a year later after i redid my clutch last year. So not bad at all for a clutch i say
94svtturbo said:
OnyxCobra said:
As much as I like my stage 2 I think next time I'm going to try that Centerforce DFX.
why is that?
supposed to be much stronger than the regular Dual Friction, yet still maintain the light, easy to drive feel. My Spec isn't bad until you get stuck in traffic, then your leg is donezo.
Win
Kennesaw, Ga
OnyxCobra said:
94svtturbo said:
why is that?
If you want something strong yet lightweight you can always go with the LMC series
94svtturbo
yeah. i would just need something to hold about 500 ft/lbs TQ. That why i was leaning to the spec stage 2
More info on the LMC series? I am unfamiliar.
I'm not making too much power but last time i was at the track i was very impressed with how my stage 2 was handling the 4500rpm launches.
