Speed calibration
dczsvt
Marshall, Missouri, United States
so my speedometer is way off (says im going 55 when im really going 45) and need it fixed, but before i do could an SCT tuner be used to recalibrate or would i have to buy the speedcal? previous owner installed 4.10 gears but didnt do anything to recalibrate
RockstarMentality
No, you have a mechanical speedo. You need either the speed cal ($100) or you can get a drive gear (like $15) and have your speedo be off 1-2 mph
jabird
Change the plastic gear on the end of the speedo. cable in the transmission. Cheap and easy.
MustangChris
Aurora, CO
if they make the right gear... 3.55 (sold by steeda) was the largest ratio speedo gear i could find.
dczsvt
dczsvt
so now i have a new problem, I went to go install my new odometer gear and when i pulled the cluster out it was rigged as fuck, i also noticed that there was some areas in the circuit pad on the back of the cluster that were burnt...and to top it off the odometer gear wasnt even broke like i had thought, but i went ahead and swapped them out anyways.....so i guess my new question is could i just get a used cluster from a 94-98 mustang?
dczsvt
dczsvt
also i should add that when i went to reinstall my cluster i DIDNT dare hook up the rigging from the previous owner and the speedometer didnt work, the odometer still didnt work and my car constantly idled at 1700rpm while i road tested it (1 mile)
Mustang Mark
i think a cluster from any 96-98 will work. it just wont be as pretty and your odometer will not be the same
in case you want to use the 94-95 you might have to rewire somethings.
dczsvt
dczsvt
so i took some pics the other day after i put it back together.....a buddy of mine says i could just run a wire to the broken area to complete the circuit but i wont get it back in the car until i install the new LED bulbs
