Nov 15, 2009 #1 F Ford Tough New Member Joined Feb 5, 2009 Messages 42 Reaction score 0 I purchased a set of 3.73 gears. What would be the most accurate speedo gear setup?
Nov 15, 2009 #2 L LAFENATU Well-Known Member Joined Nov 25, 2007 Messages 3,555 Reaction score 1 White tooth gear. 23 tooth http://www.steeda.com/products/speedometer_recalibration_gears.php
Nov 15, 2009 #3 O OnyxCobra Post Whore Joined Apr 8, 2006 Messages 14,794 Reaction score 237 Location Rochester, NY that's the closest you can get without changing the drive gear. it'll still be a little off with that gear as that's the proper gear for 3.55s. That's all assuming you have a 5 speed.
Nov 15, 2009 #4 OP OP F Ford Tough New Member Joined Feb 5, 2009 Messages 42 Reaction score 0 I forgot to say I do have a 5 speed. I think the 23 will be pretty close. Why do they sell a 23 tooth for 3.55, 3.73, and 4.10.
Nov 15, 2009 #5 L LAFENATU Well-Known Member Joined Nov 25, 2007 Messages 3,555 Reaction score 1 Not sure. The 23 tooth will set your speed off by about 5 mph.
Nov 15, 2009 #6 OP OP F Ford Tough New Member Joined Feb 5, 2009 Messages 42 Reaction score 0 So so should I use 7 tooth drive gear and the 20 driven?
