+2 on getting coilovers. Youll spend about a grand on some good springs and good struts/shocks. for about 1200-1500 you can get a good set of coilovers.
eibach lowering springs $250
Bilstein HD shocks $145 each
Bilstein HD struts $225 each
MM caster/camber plates: $210
grand total: $1200. This combo will give you 1.5" drop, good shock rebound, it will keep the springs/shock absorber separate, less wheel rate than a coilover but more than stock, and will not give you adjustability.
eibach coilovers: $1500. Will lower your car up to 2.5", more wheel rate (better handling) and give you a combo made for each other. This kit also has the rear spring/shock separate.
MM coilover kit: $1706. Comes with CC plates, adjustability of 2.5"+, front and rear springs as "one piece", much more customizable in terms of spring rates and length. Good shocks. The price is with bilstein HD struts/shocks.
BC racing coilovers: $1000. comes with Camber plates, decent on street and track, 30way adjustability. can lower up to 2.5" i believe.
I was on the same page as you. I didnt want to spend extra money on coilovers, however, when i priced everything out, the price difference was minimal. No brainer, saved up my money and bought coilovers.
