So i've been driving the car alot more now and i hear a sqeaky noise from the right side of my car . i'm suspecting its the pads and rotors. What do you guys think, and also it goes away while breaking. thanks.
Remove the wheel and look at the brake pad thickness. If any are about 1/8" or less they need to be replaced. If they appear okay there isn't anything that you can do to prevent the pads from squeaking. The squeak could also be from worn bushings in the suspension system that stop when load is applied when you are braking.
