Squeaking sounds when steering wheel turned right but not left?
Dan_T_Mustang
BC, Canada
As title says, what would cause there to be "squeaking" sounds while the steering wheel is turned to the right but while the steering wheel is turned to the left no unusual sounds are heard? =/
azmustang
Hi, I know this is an old post but my car is doing the same thing. Did you determine it was the ball joints?
Saint
Ball joints....My gt is doing the same thing now
AZ...here's how you can test...Get some Greased lightning spay lube and spray it on your ball joints, You can also use WD-40...if the squeaking goes away then ....well it is the ball joints.
Hate how the stock GT ball joints have no zurg fitting so you can grease them as a temporary fix.
Win
Kennesaw, Ga
ball joint seazing up i believe, mine did the same thing till i got mine change, good luck :thumbsup:
yes and no... Ford uses a non zirc fitting ball joint so when the grease finally breaks down that's when it starts squeezing. It's not really seizing up. Though
Addermk2
Ford Problems... they pretty much all do it. Stupid ball joints.
Jerry santos
