Squeeky...time to replace front suspension parts.
Matt94GT
Matt94GT
and i do have MM coilovers but $426.95 for MM control arms vs $100 is a big difference. Although maybe i should go that way?
you were saying a car lowered more then 1.5" on coilovers causes problems, I do want my car at my 2" drop and I do want it to handle decent, will these help correct the fact that its dropped so low?
Paul
I'm going to add my .02 here.
FWIW - I have bumpsteer adjustable outer tie rod ends on all my lowered cars. However, it has been noted here that finding an alignment shop that knows what the heck they're doing with them is pretty rare. I've actually considered just buying my own bumpsteer gauge and doing it myself. There is one shop here in town that does a decent job, and they're not far from Baer Brakes where I buy the tie-rods. (which is probably why) The reduction in bumpsteer has been tremendous. You can get it sorta close by eyeballing it and trying to get the pin in your tie rod and your ball joint to travel in the same arc. Start out by trying to get them to sit parallel at ride height, and go from there. Oh, and be careful of the "cheaper" bumpsteer tie rods. They usually come with some $.25 grade 5 bolt to attach to your spindle. You'll need to drill the spindle to make them fit since there is a taper cut into it. Plus, I just don't trust my suspension to a $.25 bolt. Conversely, the more expensive tie rods (i.e. Baer, Steeda, etc...) have a 9140 tapered chromoly pin included. This is a direct bolt-in, and makes me feel much better about the construction of my front suspension.
Ultimately, I'd go for the MM control arms for all the same reasons that have been noted in this post. However, they are pretty expensive, and I would completely understand why you would go with '03 control arms instead. I would verify that you aren't going to have any tire interference problems prior to purchasing the forward-offset control arms as well.
Matt, have you considered just swapping the whole k-member and a-arms for something like a D&D, MMR, etc.?
Paul.
Matt94GT
Matt94GT
No i have never thought about the K-memeber/arms for a new setup. To be honest my car is a weekend car/daily summer driver. Already the suspension work Ive done has made it loads better. Im trying to stop dumping loads of money into the car.
Also I can almost bet there isnt a single shop in town who will know how to do the bumpsteer kit properly thats why I havent really concidered it because it put in wrong is probably worse off then having no bumpsteer kit at all?
ps: check the valve cover thread in the garage :thumb:
bany95
Setting the bumpsteer isn't that hard once you have the tools (and have a rough idea of what you're doing). I believe MM has good instructions that you can view on their website.
Rather than buying the big bumpsteer tool with the built-in jack and dial indicator, I just made up a pair of adapter plates (which also gives a perfect place to measure toe, which you'll have to adjust after you've set bump). This worked fine for me, and I'm satisfied with the results, but the job would have been faster with the proper tool.
The problem with must "consumer" alignment shops is that they really don't know much more than how to use the big fancy computer alignment machine. Since almost no production vehicles have bumpsteer adjustment, they've likely never had to do it before... IF YOU WANT IT DONE RIGHT, DO IT YOURSELF.
bany95
I was going to upload a photo of my bumpsteer setup, but the upload folder is full... I'll try again in a couple of days.
Dalamar
SLC, UT
can you see what we're saying in this pic :p
ReplicaR
The urethane bushing equipped tubular pieces go for about 350. If you are getting discount somehow, then it's even better (let me know though PM if you are though, so far I've been paying retail with free shipping through Atomic Performance). You should have told us, that you don't feel like dumping any more money in the car, but I still think that tubular arms will be nicer at the end of the day.
Check out my posts in this thread. I went over multiple ways of how you can drop the car and still have good handling, and why a stock K-member car can not be dropped a lot.
http://www.sn95forums.com/forum/index.php?topic=25505.0
SRT Handz
Hey replicaR, SN95Forum members get 6% discount from stangsuspension.com and since they are located in So Cal the shipping is light speed.
96GTPlanB
