SS Rear Braided Brake Lines
SRT Handz
Anyone know where i can get a set of SS Braided REAR brake lines for 96-98 GT
.....MM Does not Sell these.
ReplicaR
I was not even aware there is a difference between the years. Better call them and find out why the stainless kit for 94-95 will not work. I'm pretty sure StopTech makes all of their lines anyway, so worst comes to worst, you can either call them or Earls.
SRT Handz
I have seen the J&M Lines..... wondering if Anyone else makes them also....
Once again, just playing all my options before i buy.
NXcoupe
I would like a set as well. Do they come with the bracket made onto them to mount the line?
Blind
94/95 is waaay different than 96+ rear hoses, the newer ones don't run off an axle hard line, I think it has to do with the 4 channel ABS vs 3 channel.
ReplicaR
Well I did not know that the hard lines were different, but how is having different style ABS have anything to do with the brake fluid line design. All it has to do is pass the fluid. The sensor is separate, if I remember correctly.
Blind
in a 4 channel system the ABS controls each wheel with a devoted brake line for each wheel, in a 3 channel system both rear wheels are controlled as a single channel, so if one wheel locks up the ABS pulses both rear brakes (via the single rear brake hard line)
Blind
SRT Handz said:
I dont care about ABS....Because my car doesnt have it lol
may as well go for the next mod: foxbody 4 lug drums and 10" front discs.
ReplicaR
Lol. Don't forget the 15 inch ponys and gatorback tires.
No shit. Did not know that. So, 94-95 cars are 3 channel then?
Blind
No ****. Did not know that. So, 94-95 cars are 3 channel then?
afaik, the `95 GT that I parted out about a year ago definitely was, same basic brake system as my foxbody + abs.
Win
Kennesaw, Ga
You said you didn't know where a set was.
4.698gt
I got the JM ones and they work fine no leaks. Pain to get into the passenger side rear though its an oddball spot.
