Starter Removal Question
Rizkit32
Irvine, CA
Alright guys, my transmission swap is well under way, got everything off except the starter. I can't remove the midpipe because the top bolt on the manifold flange is rounded. Is there another way I can get it off from another angle, cause it looks like my midpipe will never come off unless I cut the damn thing off
cobraracer46
BFE
You need to go to the tool store and pick up a set of these sockets that are specially made to remove rounded bolts. I have these sockets and they work good.
MustangChris
Aurora, CO
is your top bolt forward facing (head faces the front of the car) or rerward facing (head faces the back of the car)?
If its forward facing you could try and get at it with a series of long extensions from the front of the car, in between the motor-mount area....
full force
As far as the exhaust, torch it off, with as hard as it is to get to when not rounded, you wont have any luck getting it off otherwise, then replace stud in manifold...
as far as the starter, good luck they SUCK to do.... a long extension with a 13MM swivel socket can get on it, if you strip it you will be pullin g engine to get to it so be careful.... I just pull them out to tear them apart, its faster and less hassle....
330CubeGt
Just a tip, put it back in with just the bottom two bolts leave the top bolt out!
DeepList
Auburn, IN
He sold me a car with a ****ed up block and knew it ahead of time. He tried to play it off like he didn't know. No need to reply here. This guy is long gone.
DeepList
Auburn, IN
Yeah, I wasn't too happy... but whatever. I found another teksid locally for a decent price, and life goes on.
