edelbrockin7
- Joined
- Jun 12, 2011
- Messages
- 1
- Reaction score
- 0
ok so i have a 95 gt that i cant get to start.. wierd thing is .. if i hold it in the crank posistion it begins to smoke from a hole under the consol that the ebrake cable runs through to the underside of the car... if the ebrake is down the starter makes no noise is if its up it will click once when u try to start.. if u hold it in the crank posis. and slowly lower the ebrake it will click over and over.. sounds like a dead battery or a bad solenoid.. but nope niether... new starter new optima.... so... what is it!!!!!! obviously something is grounding out somwhere causing the smoke buti dont see a harness running over the or around the tranny near the hole under the consol.... im stumped and so is everyone else on all the other stang forus ive posted on.. thanks for any help!
-josh :BangHead:
-josh :BangHead:
