Stealth Mare: from the begining
Frank.JD.Perez
Pleasanton/Hayward, CA
Damn side exhaust is the shizzzz. The misfire, check ur coil. Is it higher rpm's? Or certain throttle pressure? If your getting it with throttle pressure ur car has higher mileage check ur lines u might be collapsing. Sounds good though....did u ever find the sc?
They pop up once in a blue moon when the stars all aline with the fate of the chosen ones spilt blood to bring about the legitimacy of breasts. [MENTION=7995]DropTopPony[/MENTION] has one that he's contemplating giving me...lol.. but it's throttle pressure. I can red line if I want and I do sometimes but when I go maybe 70 percent throttle now it will miss. Also my car has over 243k miles so yeah.
Nighttrain
Atglen pennsylvania
Line or injectors, might be a good time to bump ip to the 24 lb injectors anyway
Frank.JD.Perez
so like i said in the "what did you do..." thread i went and redid my calipers because i was tired of them looking like... well... :dancingpoop: ...
ANY WHO!...
on top of that i took care of the exposed wires under the splashshield (on top?...) and oddly enough after i started up the car and put on the ac (which normally as of late when i do its like... miss galore...) and there was virtually no evidence of the miss. drove her around for a tiny bit with the ac on and very small misfirage (yeah i just made a new word) and then i turned it off because i didnt really need it and now i can almost completely give the car throttle, but there is still slight misfirage. could the exposed wires cause shorting? [MENTION=20210]lwarrior1016[/MENTION] and [MENTION=11896]ttocs[/MENTION]? it did seem to make a difference. while "repairing" the wires i also moved them a bit so i could have some more clearance under the fender for the wheel and its glorious rubbing of the remaining splashshield.
now for the pictures and quick (30 sec) video
Le step dads 335
this is what they looked like due to adjustments and such of suspension and not having gloves to wear
the first coat that i started on the passenger side so i could give it time to dry while i worked on the wires
4 wires were cut on one section. you can notice the gray one up top and on the bottom the white, yellow, orange, and blue
and then i took the "splashshield" out
got them "repaired"
this is the section near the windshield wiper fluid
wrapped up and tucked up higher for some more clearance
"as you can see on the chart..." i tucked it behind the case and that little bracket thing
passenger side finished and back together as well as the driver side
YAY!
mmmmmmm....sexyyy
that blue though
and heres the video. hahah enjoy..
[video=youtube;ND_oNTT96t8]https://www.youtube.com/watch?v=ND_oNTT96t8[/video]
DKblue98GT
Wow, that was some serious tire rub. I like the blue calipers and your car is super clean for so many miles.
96blak54
Staff member
Lawrenceburg Kentucky
Videos are da chit! The car sounds awesome! Sometimes I search Ford exhaust vids through youtube. Ill be playing your vids like music! Sweet sweet music!
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
[MENTION=18830]Frank.JD.Perez[/MENTION] sorry it took so long to reply. If any of those wires were ground related then it could have caused the misfire issue, or at least contributed. Where exactly was the rub-through? Driver or passenger side, near fuse box or ccrm?
B.mad
Preferred Vendor
SoCal
They were blue since I got them. I painted then that but over time they got Hella dirty. The rears still look the same but the fronts got dirty like you can see in the post. Lol but thank ya!
Lol i know. Im just saying i like the blue
sent from the toilet or from my cubicle
jeffs mustang
