Steering wheel control help!
trytro
sioux falls sd
So somewere down the list of ownership of my 95 gt vert automatic. Someone deployed the airbags and decided to replace the steering column with a grey manual steering column. So not only do I have to mess with the stuiped key lock I also don't have steering wheel controls. I have the switches now but was wondering if there was a way I can use them with the steering column, or If anyone has a black steering column with controls pm a price. Any help/how's to's would be great!
pretty sure the wiring is there no matter what the style. getting the wheel off is pretty easy, only takes 3 bolts and then you can see if you see the wires there. Otherwise take the next piece down and look.
PM sent on steering column.
As for right now, remove the airbag (unplug the battery, let sit for a few minutes. Then there are two plastic circle tabs on each side of the steering wheel. pop these out and remove the two screws behind them. Once they are out the airbag slides forward.) and check the wires inside the wheel, as well.
