dklimek said:
bottlefed97 said:
dklimek said:
Are you lifting when you shift? Pull your filter? Bet you you'll gain your 10th from those alone.
What pressure are you running? Do you check them in between passes?
Yep I lift between shifts, I would power shift but my tranny is weak enough as it is lol. I've never pulled my filter before, because of all the dust/rocks at the end of the track.
I run 11psi in the rears, and I check/adjust em before every pass.
Mine is in the engine bay so I don't have to worry about that, and I also pulled the pass headlight out at the track. I hear you about the lifting...I would be too antsy though. Damn thats just TOO close! Why is it only 1.7 60 footing? What tires/suspension are you running? I'm assuming you've pulled the front sway?
I'm running Mickey Thompson drag radials. My suspension consists of:
PA Racing Tubular K-Member
Steeda X2 Ball Joints
Strange Adjustable shocks
Granatelli Coil-Over Springs
Granatelli Subframe Connectors
UPR up/lwr control arms
I've never taken off the sway bar for the track. I think a 1.7 is pretty decent. It'll get better over time though.
