Stock Vortech v-2 pulley size?
Does anybody know what the stock pulley size no the vortech v-2 for our cars is? I've e-mailed vortech 3 times and still no answer. The numbers are rubbed off on my pulley some how?
Any help would be greatly appreciated.
Also, instead of making a new thread, I'll just ask it here. What size injectors would you use on a stock 5.0 motor thats running 11 psi? I want to go down one pulley and put my AFM powerpipe on.
LAFENATU
Stock pulley on an S-trim is 3.33
The next pulley down is a 2.95
As far as injectors...I take it you are using a FMU?
LAFENATU
I would do a new 255 hi-pressure fuel pump and a set of 42lb injectors.
mikey94gt
either that, or Granatelli makes a drop in pickup for the stock tank that runs AN lines, and you can go with a huge external pump, without hacking up the car.
I bet the 255 will do the trick, as that should flow 67GPM, and a 450CHP car should use about 50, figured at 80% working volume.
