stroke'n it.
vermilion
maryland
i called MMR and ordered the mod stroker 850 rotating assembly :headbang: . i cant wait to see it in 2 weeks and pictures will come through. :bootyshake:
duff daddy
sweet, alot of people have good luck with them but others dont. any specs on the pistons? dish ect?
vermilion
vermilion
maryland
aluminum wap block out of an explorer. its had machining done before i bought it but you couldnt tell its been in a vehicle. mainly deburred. i found it locally for 200 bucks with stock rotating assembly. it had flat top pistons and billet main caps. im punching it .020 over and i thought about a main girdle but i was advised i dont need it. my main goal is 400 and realistically i can get it. im putting an intercooled v-2 sq on it with 42lb injectors and my built heads. i also have the reichard racing intake manifold so up top of the revs is where my power will be. next is fuel system and 31 splined axles.
duff daddy
THAT SOUNDS SICK. i wanted a wap block but no one had one that was cheep enough and decent shape. we had one here at work but i found it was pretty well roasted so im going a different route now but def gonna be where you want for numbers, were you saying 400 NA or 400 F/I
vermilion
vermilion
maryland
forced induction. im going to keep the boost low and moderate until i get a new tranny. the t-45 wont take much more. ill be looking for a t-56 or tko-600. i cant part with a manual because i like rowing my own boat. i was spanked last night by a termy and lightning and i need to keep up. hell even a bullit whooped my ass in this old slug.
duff daddy
a t45 is alot stronger then you would think. if you get them built with good shift forks and quality syncro's i think you will be more then happy.
and a stock 02 gt with an exhaust and ysi made over 420rwhp with no tuning and about 12lbs
vermilion
vermilion
maryland
i was also looking @ promotion t-45.... 12lbs of boost was my idea but intercooled maybe 10lbs. with the wap block and tubed k-member/a-arms i should be able to giddy up quicker. ive been stock piling forever and recently full swing into it. my suspension is pretty good right now. i need to empty my storage area. then i can paint the ole girl. she needs it. fuel system/braking/rearend.
