strong collant smell when heat is on
96dkgreengt
So recently I was sitting at the airport waiting for my brother to come in when all of a sudden I smelled collant, my car does not overheat or leak anything on the floor, but when I have the heat on all my windows fog up and I smell a stong smell of collant.. I checked all the hoses for leaks and nothing.. also my collant does not get low in the system.. I am assuming its a bad heater core :crybaby2: but not positive yet.. any one have suggestions on anything else it could be that I should look into???
As far as a headgasket I thought the car would over heat which it doesn't so that's y I wasn't looking into it being a headgasket just yet
Venomous96Cobra
Central Florida
bad heater core! the strong coolant smell means it is starting to leak into the car... you should fix that a.s.a.p before you have a major coolant leak inside your car! or bypass it until you can replace it.
96dkgreengt
damnn.. i was hopeing there was something else that couldve been wrong.. i dont drive the car much at all so maybe ill begin the teardown to change it out this weekend..
mike97gt
Red Deer, Alberta, Canada
check both firewall connections for any leak. i blew my one heater hose and replaced it with one that day but smaller OD doesnt keep it as tight as it should. it leaks a very small amount but every time i turn the heat on it smells like coolant for a few seconds before it goes away.
if it stays that way then you have a cracked heater core.
good luck
Dws 95 mustang GT
