Stupid High Pitch Noise
venom
To rule out the belt. You squirt water in the grooves of one of the pulleys with a spray bottle. If it goes away could be a worn belt.
g36 monkey
Orlando, Fl
I am racking my brain and not remembering a cam synchronizer. I mean the cam is synchronized because of the timing gears...no?
Johnnym1
Cam synchronizer? Elaborate please.
It looks like a 3.8l. They have cam synchro's that look like a distributor cut in half. You can take cam synch out and lube it. This will buy you a little time if it isn't wore to bad and has alot of slack. You will need to mark it so that it goes back exactly the way it come out.
g36 monkey
Orlando, Fl
O lol I used to take that thing out all the time thinking it might have been causing my running trouble. ;p
