Stupid ?
uncltrvlnmatt
Pa.
Where is the best spot to hook up the chains to lift out the engine from my Mach. I can't drop it out the bottom safely, so it is coming out the old fashoned way. I normally use bolt holes in the front and rear of the heads. But you cant do that with this thing, and I don't know if I trust the intake bolts. They seem awefully small for the weight of the engine.
Sugestions?
jfor441
Matt... Here's some pics a buddy of mine took when he was installing his motor from the top. Take a look at them and see if you can tell where he hooked the chains to.
U
uncltrvlnmatt
Pa.
Thanks Josh, that was helpful. It looks like he used the bellhousing bolts on the back side, but the front is tough to tell. I will check my engine the next time I am there to see where he mounted the fronts.
AaRoN
King Post Whore
I used the manifold studs. Another thing you can do is either call the dealership or a parts store and order brackets that fit on either side of the motor specifically designed so you can lift it out.
U
uncltrvlnmatt
Pa.
I stopped at the dealer today. Their mechanic said either use the exhaust manifold boles, or lift it out by the exhaust manifolds. They also said I should split the trans.
I told them the car was junk and I would just cut out the radiator supports in the front.
AaRoN
King Post Whore
Yeah, the manifold studs were the best spot I could find.
