Super Tune Up!!! Anything missing?
reldapimp
Motorcraft Oxygen Sensor x 2(For my bad o2's)
180 Mr Gasket Thermostat
Motorcraft Coolant Temperature Sensor
Idle Control Valve Idle
MSD Cap and Rotor
NGK Spark Plug
Accel Ignition Wire Set Ignition Wire
Motorcraft EGR Valve EGR Valve ( For my Code 322)
Fuel Filter
PCV Valve
New Motormounts
Home Depot Air Intake (And doing the stuff in the sticky to fix my sloppy idle)
Oil Change
When everything arrives I will install/do everything all at 1 time. Is there anything else I need while im doing all of this and waiting for UPS to arrive?
El_Diablo
im anal and perfer denso o2's
why not msd wires?
avoid fram filters.... and why cheap out on the intake?? if your dead set on that then i would atleast suggest an s&b filter... not that it will do much good over a k&n on most of the homemade jobs out there
Paul
Bleed the brakes.
Clean the MAF.
Check/replace Trans mount if necessary.
I don't know if you need to replace the IAC. You can try cleaning it first. Same with the EGR.
Paul.
Homemade intake will be fine. They work just as good as anything else out there, and maybe a littel better since they're made of plastic and not metal.
Why not cheap out on the intake?
R
reldapimp
I got the MAC intake...
I already have all the parts so everything is just getting replaced... Im also gonna do an oil change.
I will look into the trans mount...
