4.6Stangrage
I found a super clean P71 engine at Pick n pull the other day. I scored it for $200!! Anyways, I am going to pretty much directly swap it but swap my PI intake and my stock '96 timing cover. I could probably compare the oil pans when I have the old engine out, but will the crown vic oil pan work in my '96 GT? I also have the stock pressure plate from the Crown vic which probably wont work with my gt. Other than that, the water pump and the rest of the long block will be swapped into my GT. Is there anything i should know before doing the swap?
Thanks,
Randy
Thanks,
Randy
